bengrech wrote:Is there some ready-made board say with a DB9 or direct pin connections?martinayotte wrote:BTW, it is even worst : real RS232 signal is swinging between around -7V and +7V, inverted compared to TTL side, -7V is HIGH and +7V is LOW.
You need to use some interface chip such as MAX232, which built the +-7V out from 5V using internal charge pumps.
YES. Check ebay for rs232 to TTL converters/adapters.
