uhrheber wrote:http://www.aliexpress.com/item/ESP8266- ... 33472.html
I received the board yesterday.
Tried to get the board running with the Android app, but couldn't, because the board comes preconfigured with a password protected AP, and I couldn't find the password anywhere. So I flashed NodeMCU and played around with the LEDs.
The board has:
- ESP-12 module (with blue LED at TX)
- pin headers for all pins of the ESP-12 (standard pitch 0.1")
- 3.3V regulator
- extra 3 pin header for RxD/TxD/GND
- jumper to connect GPIO0 to ground (to enter flashing mode, all other GPIOs are already at the right level via resistors)
- 6 red LEDs
- 1 RGB LED (and spare pads to use 3 0603 LEDs instead)
- a battery holder (3xAA) soldered to the board
- 1 LDR connected to the ADC input
Flashing worked flawlessly (the board comes with the flash mode jumper already installed). I used a CP2104 board for the USB to serial conversion.
I think this is a nice little board to get you started, but still cheap enough to use it in a permanent IoT device.
Just connect some sensors/relays/buttons/LEDs/buzzers/whatever with jumper cables and you have a nice unique solution without soldering a single wire.
