Re: NodeMCU ESP-12 Dev board with onboard TTL Serial reset l
Posted: Tue Jul 21, 2015 9:55 pm
I've now tried with additional USB powered hubs... The AT command firmware seems to work, however once I flash nodemcu with the default settings from here:
https://github.com/nodemcu/nodemcu-flas ... lasher.exe
(I've tried many other options)...
I get the same results.... wdt reset at 115k baud. If I hold the chip, touching most of the pins, it boots nodemcu, but then resets a few seconds later still.
I'm going to try to get another board I guess to see if the problem follows.
/Disappointed so far
Edit: New chip arrives in one week. Hopefully it is just an obscure hardware problem, if not I'll read some more.
