Re: Esp don´t flash the firmware
Posted:
Sat Jul 25, 2015 2:52 pm
by jmalm
I'm trying flash the AT firmware and use Arduino UNO to flash it.The process I follow is I hold GPIO0 low, since the power is ON until the flash finish, disconect GPIO0 and power, i return power it and the ESP dont start, the blue led always is ON, and dont blink. Power... I use a PC power supply... Should reset from pin?
Posted:
Sat Jul 25, 2015 4:32 pm
by kolban
To flash the device, GPIO 0 should be low, GPIO 2 should be high when the device is booted. At this point, the device is read to program. Now you can flash it.
Perhaps if you attached a photograph of your setup, that would help.
How are you powering the device?
Posted:
Sun Jul 26, 2015 1:49 am
by Maker
Perhaps it is a different using with the arduino. I am using nodeMCU and the programming adapter I told about
viewtopic.php?f=13&t=4132I do it the way I wrote and it works fine.
