By kenn
#15916
Sweetpants wrote:
zioax wrote:I've tried adding a 15k pull-up resistor to RST, but after a few of on/off,it had crashed and I had to reset it manually.
A pull-up will not help you as it is already pulled-up internally
That's not strictly true. The internal pullup may be 'weak', and the addition of a 'stiffer' external pull-up resistor can add noise immunity. Instead of 15k, try ... 1k. If you're never going to use the RST input, just tie it to Vcc. A pull-up resistance of about 0 ohms. :)
To those using electromechanical relays and still having reset problems... are you using a snubber diode across the relay coil? Google it.
