Finaly came around to test more of the board. It seems to work so we didn't receive a fake chip \o/
Hooked my trusty old buspirate to it and the bootloader talked to me <3:
Code: Select all ets Jan 8 2013,rst cause:2, boot mode:(3,7)
load 0x40100000, len 24236, room 16
tail 12
chksum 0xb7
ho 0 tail 12 room 4
load 0x3ffe8000, len 3008, room 12
tail 4
chksum 0x2c
load 0x3ffe8bc0, len 4816, room 4
tail 12
chksum 0x46
csum 0x46
If someone else uses a buspirate to monitor the bootloader, here are the commands:
Code: Select allHiZ>m 3
Set serial port speed: (bps)
1. 300
2. 1200
3. 2400
4. 4800
5. 9600
6. 19200
7. 38400
8. 57600
9. 115200
10. BRG raw value
(1)>10
Raw value for BRG (MIDI=127)
(34)>51
Data bits and parity:
1. 8, NONE *default
2. 8, EVEN
3. 8, ODD
4. 9, NONE
(1)>1
Stop bits:
1. 1 *default
2. 2
(1)>
Receive polarity:
1. Idle 1 *default
2. Idle 0
(1)>
Select output type:
1. Open drain (H=Hi-Z, L=GND)
2. Normal (H=3.3V, L=GND)
(1)>2
Ready
UART>
UART>
UART>(1)
UART bridge
Reset to exit
Are you sure? y
