Re: ESP12E Useable pins and schematic feedback
Posted: Tue May 29, 2018 10:15 am
The image isn't big enough to make out enough detail. It would be good to see the layers separate. But from what I can make out:
Suggestion, get rid of pads 17-22. You will not use them and they restrict you.
The trace from pin 4 (GPIO16) is shorting to pin 9 (GND). You need more clearance.
It looks like most of your small parts that have connections to 3.3v or gnd have the pad fully merged with the copper pour. This is a problem when it comes to soldering. The copper will suck away the heat from the pad. It is desirable to have the pad with space around it and connect to the copper plane with trace segments.
Make sure your vias have a large enough diameter pad, taking into account the via hole diameter.
Your traces look thin too me. I try and use 0.010" as the width, 0.008" minimum.
I tend to use 0805 parts as they are easier to work with.
I recommend having a pull up on the RX line. Some modules will not start up properly if it is not high.
I would add pull ups on the other pins. You don't have to populate them, but if you need them later it is easier if there was a spot for it already.
Use a heavier trace for GND to the module. You did for VCC, so why not for GND.
