By hbouzas
#10115 Finally I got the ESP8266-03 working properly and all setup to control 4 relays or any other small current signal. I Customized the LUA firmware to control the GPIO pins, plus I don't need to set it up via serial, I can do all the wifi setup via a web browser which makes it really convenient for large deployment, also integrated in the board a reset and flash switch. This little thing is a beauty.
You can checkout the project on www.horaciobouzas.com
Comments?
