By AdeLast
#89386 Hello team,
I have setup a tiny project and currently my ESP01 is running with two AA battery. However they last very little so I'd like to change that power source and use an external USB charger.
I have never done such thing, can someone please point me in the right direction? I guess that just take a USB cable and connect the positive and negative is not enough as the power supply won't adjust the voltage, right?
Many thanks!
By btidey
#89403 To power your ESP-01 from a USB power source you need to regulate the 5V USB voltage down to 3.3V required by ESP-01. You cannot connect it directly.
You have 2 choices.
1 A small buck converter search on eBay for buck converter mini and make sure you adjust output voltage to 3.3V before connecting to ESP-01
2. A LDO 3.3V linear regulator like an XC6203E332PR-G This will be your smallest option if space is limited. Good to put a capacitor across the 3.3V output (e.g. 220uF tantalum.
