By dirkx
#14000 By defining USE_US_TIMER and using system_timer_reinit() one can get microsecond accurate timers.
However it seems that setting the timer with
os_timer_arm(&some_timer, 5000, 1);
is still done in microseconds. Is that correct ? Is there a way to set it microsecond accurate - I am trying to bitbang a SMPTE timecode with a jitter ideally well below a few 100 micro seconds/bit.
Thanks,
Dw.
By Vijay Sharma
#14853 Hi Dirkx, I also have the same issue. I need a timer with microsecond accuracy but delay() does not give so. Can you tell me more on how are you using the below code, I may be able to dig in ?
By dirkx
#15116 Turns out there is a new function (not quite part of the header files yet):
ets_timer_arm_new(&some_timer, timeInMicroSecOrMiliSec, repeat, X);
where X=0 means microseconds and X=1 means milliseconds.
Dw.
