MicroPython v1.19.1 on 2022-06-18
They scan the network fine, but won't connect to the router.
I've tried the usual, disconnecting, setting active false, before going active and connecting.
Powered via USB, from a USB3 port that can supply more current than the boards could need.
The same code works fine on other ESP32 and ESP8266 boards, on the same desk, to the same router.
I guess I can try external power, and I can use other modules, I just would like to get these modules to be usable as well.
My only other thought they may have an issue with the pcb antenna.
Any suggestions?
