There are a number of regulators that will do the job. I normally use XC6303
Explore... Chat... Share...
davydnorris wrote:Does the ESP-01 board have a LED? Is it on when you turn on the switch?
Would be really good to see the current draw - can you wire a multimeter into the circuit?
Also what is your sketch doing? If you have the wifi turned on then the current draw is quite high
btidey wrote:I think the problem is with the choice of regulator. The HT7133 is a low power regulator designed to supply currents up to about 30mA. The ESP8266 modules require a powering with something that can supply 500mA peak although the average operating current is about 80mA.
You really need to point us to the project you're […]
you can check in github esp8266 rtos examples ther[…]
yes, but even before summer time there was the sam[…]
According to the ESP8266EX Data sheet Pin 6, TOUT[…]
Hello, I would like to tell you about a problem I'[…]
Thanks for all comments so far... Also received so[…]
I am trying to assemble an external antenna design[…]
Hello... I am pursuing Ph.D. from JNU, New Delhi. […]
This question was already once asked. Check this […]
Update: Switched to NodeMCU V1.0 (Amica) and tri[…]
Follow US on Twitter and get ESP8266 news and updates first.
