Fixing the I2S driver in ESP8266 RTOS SDK
The current example code for the I2S peripheral in ESP8266 RTOS SDK doesn't work at all. There's an open issue on GitHub without a fix. The problem is in the driver code.
I was able to squeeze out valid I2S signals of the chip without using the driver, just by direct register manipulation. However, I couldn't get the SLC interrupts working which is exactly the problem with the RTOS driver as well.
Unfortunately I couldn't find any information on how to enable SLC interrupts. The only description out there is a header file (actually two, slc_struct.h and slc_register.h, but they contain the same information in different formats) without any instructions on how to make the interrupts work. The most detailed hardware document I found provides no details either.
Anybody knows how to do this? Can somebody from @espressif comment on this?
