By bobricius
#18140 hi, I want present my new board.
Features:
USB is only for power > easy to create wifi node with your old phone charger
onboard RGB 5050 led
onboard 3.3V regulator
onboard switching transistor for inductive relay load
upload button
female USB for output load
all signal are in one row for easy breadboard experiments
USB connector for connecting small load (LED lamp) or relay
Design files:
https://github.com/bobricius/ESP8266-node
If you interested to buy, I have some boards on tindie
https://www.tindie.com/products/bobricius/esp01-esp8266-usb-node-rgb-adapter-relay-driver/
or ebay
http://www.ebay.com/itm/ESP01-ESP8266-USB-node-RGB-led-adapter-relay-driver-Arduino-nodemcu-elua-/321748345421?
