By YellowSky
#18814 Hi everyone,
sorry if it is not the good section to post this...
I have a ESP-01 with a simple program (init.lua). Basically
1. Variables Initialisation
2. while (1==1)
some actions
During the while loop i can't communicate with ESPlorer (by serial) with the module. So if i have a problem in the code, i can't restart or i can't remove the init.lua to load another one.
Each time i must flash the module and the load a new init.lua file.
I try to put a delay between the variables initialisation and the while loop but during the delay i can't communicate with the module anymore...
Any solution on this problem?
Thx
By cal
#18878 Moin,
you have to change you style of programming to event style. (Hmm does that sound like a fashion tip?)
I suggest starting with this:
https://github.com/TerryE/nodemcu-firmw ... ficial-FAQ
and taking a look at the lua examples.
There is an extra area for lua nodemcu related questions. here:
viewforum.php?f=17
Welcome,
Cal
