By mbbackus
#24355 The button is definitely useful - just need to pull it up whenever you use it. Here's an example that controls the LED onboard the ESP8266. As a side effect, the LED attached to pin 16 (the LED next to the user button) also lights up whenever the button is pressed.
Code: Select allconst int buttonPin = 16;
const int ledPin = 1;
  pinMode(buttonPin, INPUT);
  pinMode(ledPin, OUTPUT);
  if (digitalRead(buttonPin) == HIGH)
    digitalWrite(ledPin, HIGH);
    digitalWrite(ledPin, LOW);
    pinMode(buttonPin, OUTPUT);
    digitalWrite(buttonPin, HIGH);
