Re: NodeMCU - running arduino - User Button
Posted: Fri Oct 09, 2015 12:16 pm
I'm not sure on the circuit, but the posted code on my NodeMCU 0.9 wasn't quite right. As far as I can tell pin16 is multiplexed for both the button and the LED.
If the button is active then the LED is off until the button is pressed.
If the LED is active the button is disabled and the LED is on.
There's clearly one more combination, as at boot up the button doesn't illuminate the LED. I've not however figured out that combination but I'm thinking an internal pull-up/drain setting on the GPIO. Maybe there is a relationship with pin #1; regardless, I could not get the LED to flash if the button was active.
I therefore went for this combination:
const int buttonPin = 16;
void button(bool enabled)
pinMode(buttonPin, OUTPUT);
digitalWrite(buttonPin, enabled ? HIGH : LOW);
if (enabled) pinMode(buttonPin, INPUT);
void flash()
for (int i = 0; i < 5; i++)
button(false); // Toggle button makes LED go on/off
delay(100);
button(true); // Toggle button makes LED go on/off
delay(100);
void setup()
button(true);
flash();
bool wait_for_release = false;
void loop()
if (digitalRead(buttonPin) == HIGH)
wait_for_release = true;
else if (wait_for_release)
flash();
