By jmalm
#24251 I'm trying flash the AT firmware and use Arduino UNO to flash it.The process I follow is I hold GPIO0 low, since the power is ON until the flash finish, disconect GPIO0 and power, i return power it and the ESP dont start, the blue led always is ON, and dont blink. Power... I use a PC power supply... Should reset from pin?
By kolban
#24258 To flash the device, GPIO 0 should be low, GPIO 2 should be high when the device is booted. At this point, the device is read to program. Now you can flash it.
Perhaps if you attached a photograph of your setup, that would help.
How are you powering the device?
