By WolfReverse
#24491 It sends: "AT<CR><LF>"...
I don't know if it's normal, but when i send commands to the module the blue led don't flash, but the TXD on the FTDI does.
EDIT: Ok i've tried flashing NodeMCU and it worked, but it's the same situation, i can't send commands and i can't upload lua files.
I've tried also using LuaLoader instead of ESPlorer but it's the same..
By tytower
#24616 Try other baud rates then if something is comming out, but It sounds to me like you are just getting a continual reset . Do you have XPD pin connected to reset perhaps . I had that with an esp12 . Used a cap instead and it ran properly .
If it is a continual reset then check your wiring through . Perhaps try to put more info here about your circuit and what you are doing.
