By MajorMadness
#26713 Hello together,
I started to play arround with some ESP Models a few weeks ago and run into a Problem with the ESP-13:
Normally there is a CH_PD Pin, but I only see EN, which is maybe the same. The other pin I wonder about is TOUT I can't figure out.
Before I burn the chip I wanted to ask if it's right to connect EN to VCC?
Thanks for help!
Greettings
By kolban
#26730 I think your guesses are sound ... it is "likely" that EN is CH_PD (chip enable) and should be high for normal operation. The TOUT labeled pin matches what I know about the analog to digital converter which is called "TOUT" in the ESP8266 specs.
Neil
By MajorMadness
#26851 Hi Neil,
Thx for the reply. I tested it and you are correct. En is ch_pd like I was guessing. Low for programming and high for normal operation.
Tout as AD converter I couldn't test yet but I'll check data sheet and try it later on.
Thx Moritz
