Re: Low Power Battery Powered Surveillance Application
Posted: Wed Apr 13, 2016 7:26 am
Hello!
You wrote than you power ESP with AAA batteries. Say please how much and what kind of AAAs you use? If you use 2 typical batteries it means that you power your ESP with 3 volts and it works?
In code I see you check low battery at 2.4 volts. Is ESP correctly works on (2.4-3) volts? As I see in specification, it says that we should power our ESPs with (3-3.6) volts...
