Page 1 of 2
AT+PING IS NOT WORKING
PostPosted: Wed Aug 31, 2016 3:11 am
by shajibahmedwow
Hello. I am using ESP8266 with FTDI232. I am trying to ping. but it doesn't work. AT, AT+GMR,AT+CWLAP,AT+CWMODE, AT+CWJAP are working well. when I use AT+PING="www.facebook.com" it doesn't work. importantly AT+PING is not working. it shows error.
Can anyone have the solution ?
Re: AT+PING IS NOT WORKING
PostPosted: Wed Aug 31, 2016 2:07 pm
by maxime1234
Hi,
I have the same problem right now using the ESP8266 from arduino.
I'm connected to my local network with a client IP and stuff but there is no way to ping google.com or any other computer on my local network.
If you find a way to make it work on your side, please let me know here.
PostPosted: Thu Sep 01, 2016 1:01 am
by techiesms
May be it require a firmware upgrade.
Because I faced similar problem but with another AT command
AT+CIOBAUD was not working in my older firmware
And after I updated the firmware of ESP that command is perfectly working now.
If you don't know how to upgrade the firmware, I have made a tutorial video on that. Hope that helps you out
https://www.youtube.com/watch?v=XYYjlZs35a4
PostPosted: Thu Sep 01, 2016 11:58 am
by maxime1234
Is this the latest firmware? Thank you for your help!
