By RichardS
#43228 User
sakeito
Description
It has the following advantages.
-The original wild mini4WD can run only forward. But, in this project
you can control forward and back , right and left by the smartphone.
- Since retrofitting the existing plastic model, you can choose a
variety of car body.
- The front wheels to create a steering in a 3D printer, it turns to
the left and right by a servo motor
- The rear wheel controls the forward-reverse in the motor driver.
- The headlights and brake lamp are luminous.
-Source code, using the Arduino IDE, you can easily change.
-Because using browser, you can use only Android smartphone, but also
iPhone and tablets.
- Since you can create all the way in one day, even if you are
interested in e-work.
-Already done three time workshop, enjoys about 50 people.
-This workshop has sold out every time in about 10 minutes after the
recruitment in popularity.
Parts
Links
Homepage
Video
Images
(3.21 KiB) Downloaded 320 times
(8.47 KiB) Downloaded 597 times
(164.26 KiB) Downloaded 337 times
