Questions with regards to ESP8266 Basic and hardware interfacing and control via Basic commands
By Tsoved
#84922 Hello!
I'm new with the use of ESP8266-01 module. I tried to program it with the AT command and it work well but not like I wanted. After that, I found out the basic flasher and wanted to test it. However, I found out after downloading the V3.69 that the ESP8266-01 is not support anymore. Is that correct or I'm just wrong? In the case that i'm correct, does the last version (like the 2.0 branch thing) could support it??
Thank you for your time!
-Tso
