ESPUSB - Chat about the software components
By AKA
#84300 The problem does not save the wi-fi network settings in flash memory.
I need the connection to be on the home wi-fi network.
I change setting "ssid:" and "pass:" further I press "change setting" there is a connection to a home network. But if you pull out and reinsert the USB connector ESP8266 then the settings are all default.
By timg11
#93627 I realize I'm late to this party, but I recently have a need to simulate a USB keyboard and control it by Wi-Fi. This seems like the perfect solution.
However, I need to configure the ESPUSB device to connect to an existing Wi-Fi network as a client and use DHCP. It appears the default behavior is to create an AP.
I have reviewed all the code in espusb-master.zip from https://github.com/cnlohr/espusb, and I don't find anything related to WI-Fi setup. I'm able to compile the network SSID and WPA into the image, since this is a "one off" custom application. How would I do that?
By timg11
#93628 After further work, I found this is a reported issue in cnlohr's github page
Nobody has solved the problem of saving the settings to flash (as the web gui implies will happen).
The workaround is to change user_main.c so the board initiates into station mode.
This does require compiling the the SSID and WPA password into the code so it is not ideal, but usable for a one-off project.
It is not clear how to integrate the sample code into user_main.c, so here is the modified source that will compile and run:
Code: Select all//Copyright 2015 <>< Charles Lohr, see LICENSE file.
// Modified by TG for Wi-Fi Station mode at init 2022-02-11
#include "mem.h"
#include "c_types.h"
#include "user_interface.h"
#include "ets_sys.h"
#include "uart.h"
#include "osapi.h"
#include "espconn.h"
#include "commonservices.h"
#include <mdns.h>
#include <esp82xxutil.h>
#include <gpio.h>
#include <common.h>
#include <usb.h>
#define PORT 7777
#define procTaskPrio        0
#define procTaskQueueLen    1
static volatile os_timer_t some_timer;
//int ICACHE_FLASH_ATTR StartMDNS();
void user_rf_pre_init(void)
   //nothing.
char * strcat( char * dest, char * src )
   return strcat(dest, src );
//Tasks that happen all the time.
os_event_t    procTaskQueue[procTaskQueueLen];
//Awkward example with use of control messages to get data to/from device.
uint8_t user_control[144]; //Enough for FW######## ### [128 bytes of data] [null]
int     user_control_length_acc; //From host to us.
int     user_control_length_ret; //From us to host.
void usb_handle_custom_control( int bmRequestType, int bRequest, int wLength, struct usb_internal_state_struct * ist )
   struct usb_endpoint * e = ist->ce;
   if( bmRequestType == 0x80 )
      if( bRequest == 0xa7) //US TO HOST "in"
         if( user_control_length_ret )
            e->ptr_in = user_control;
            e->size_in = user_control_length_ret;
            if( wLength < e->size_in ) e->size_in = wLength;
            user_control_length_ret = 0;
   if( bmRequestType == 0x00 )
      if( bRequest == 0xa6 && user_control_length_acc == 0 ) //HOST TO US "out"
         e->ptr_out = user_control;
         e->max_size_out = sizeof( user_control );
         if( e->max_size_out > wLength ) e->max_size_out = wLength;
         e->got_size_out = 0;
         e->transfer_done_ptr = &user_control_length_acc;
uint8_t my_ep1[4];
uint8_t my_ep2[8];
extern uint32_t usb_ramtable[31];
extern int keybt;
extern int keymod;
extern int keypress;
static void ICACHE_FLASH_ATTR procTask(os_event_t *events)
   struct usb_internal_state_struct * uis = &usb_internal_state;
   struct usb_endpoint * e2 = &uis->eps[2];
   e2->ptr_in = my_ep2;
   e2->place_in = 0;
   e2->size_in = sizeof( my_ep2 );
   if( keypress && e2->send == 0 )
      my_ep2[0] = keymod;
      my_ep2[2] = keybt;
      e2->send = 1;
      keypress = 0;
   CSTick( 0 );
   if( user_control_length_acc )
      //printf( "\nGot: %s\n", usb_internal_state.user_control );
      int r = issue_command( user_control, sizeof( user_control )-1, user_control, user_control_length_acc );
      user_control_length_acc = 0;
      //printf( "%d/%s/%d\n", usb_internal_state.user_control_length_acc, usb_internal_state.user_control, r );
      if( r >= 0 )
         user_control_length_ret = r;
   system_os_post(procTaskPrio, 0, 0 );
//Timer event.
static void ICACHE_FLASH_ATTR myTimer(void *arg)
#if 0
   struct usb_endpoint * e1 = &uis->eps[1];
   int i;
   //Send mouse and keyboard commands
   //my_ep1[0] ^= _BV(1);  // _BV(x)  ((1<<(x))
//   my_ep1[1] = 1; //X offset
//   my_ep1[2] = 1; //Y offset
   //[0] == Button Bitmask ( _BV(0) == the Left button )
   //[1] == The X offset
   //[2] == The Y offset
   //[3] == ?
//   my_ep2[2] ^= 8;  //Keyboard
   printf( "%d\n", e1->send );
   e1->ptr_in = my_ep1;
   e1->place_in = 0;
   e1->size_in = sizeof( my_ep1 );
   e1->send = 1;
   e2->place_in = 0;
   e2->send = 1;
#endif
   CSTick( 1 );
void ICACHE_FLASH_ATTR charrx( uint8_t c )
   //Called from UART.
volatile uint32_t my_table[] = { 0, (uint32_t)&PIN_IN, (uint32_t)&PIN_OUT_SET, (uint32_t)&PIN_OUT_CLEAR, 0xffff0000, 0x0000ffff };
#ifdef PROFILE
int time_ccount(void)
        unsigned r;
/*   volatile unsigned a = 0xabcdef01;
        asm volatile ("testp:");
   a &= ~(1<<10);
        asm volatile ("\
   \n\
intrs: \
   call0 my_func\n\
   j end\n\
\n\
end:\n\
   \n\
   sub %[out], a11, a9\n\
   " : [out] "=r"(r) : : "a9", "a10", "a11" );
        return r; //rsr a9, ccount //rsr a11, ccount
//   addi %[out], %[out], -1\n\
#endif
void user_rf_cal_sector_set()
LOCAL os_timer_t test_timer;
 * FunctionName : user_esp_platform_check_ip
 * Description  : check whether get ip addr or not
 * Parameters   : none
 * Returns      : none
user_esp_platform_check_ip(void)
    struct ip_info ipconfig;
   //disarm timer first
    os_timer_disarm(&test_timer);
   //get ip info of ESP8266 station
    wifi_get_ip_info(STATION_IF, &ipconfig);
    if (wifi_station_get_connect_status() == STATION_GOT_IP && ipconfig.ip.addr != 0) {
      os_printf("got ip !!! \r\n");
    } else {
        if ((wifi_station_get_connect_status() == STATION_WRONG_PASSWORD ||
                wifi_station_get_connect_status() == STATION_NO_AP_FOUND ||
                wifi_station_get_connect_status() == STATION_CONNECT_FAIL)) {
         os_printf("connect fail !!! \r\n");
        } else {
           //re-arm timer to check ip
            os_timer_setfn(&test_timer, (os_timer_func_t *)user_esp_platform_check_ip, NULL);
            os_timer_arm(&test_timer, 100, 0);
 * FunctionName : user_set_station_config
 * Description  : set the router info which ESP8266 station will connect to
 * Parameters   : none
 * Returns      : none
user_set_station_config(void)
   // Wifi configuration
   char ssid[32] = "YOURSSID";
   char password[64] = "YOURWPAPWD";
   struct station_config stationConf;
   os_memset(stationConf.ssid, 0, 32);
   os_memset(stationConf.password, 0, 64);
   //need not mac address
   stationConf.bssid_set = 0;
   //Set ap settings
   os_memcpy(&stationConf.ssid, ssid, 32);
   os_memcpy(&stationConf.password, password, 64);
   wifi_station_set_config(&stationConf);
   //set a timer to check whether got ip from router succeed or not.
void ICACHE_FLASH_ATTR user_init(void)
   uart_init(BIT_RATE_115200, BIT_RATE_115200);
   uart0_sendStr("\r\n\033c" ); //Clear screen
   uart0_sendStr("esp8266 test usb driver\r\n");
   system_update_cpu_freq( 80 );
//#define PROFILE
#ifdef PROFILE
   uint32_t k = 0x89abcdef;
   uint8_t * g  = (uint8_t*)&k;
 system_update_cpu_freq(160);
   my_table[0] = 5;
   printf( "%02x %02x %02x %02x\n", g[0], g[1], g[2], g[3] );
   uint32_t rr = time_ccount();
   printf( ":::::%d / %02x / %d\n", rr, rr, my_table[0] );
   system_restart();
   while(1);
#endif
   //Print reboot cause
   struct rst_info * r = system_get_rst_info();
   printf( "Reason: %p\n", r->reason );
   printf( "Exec  : %p\n", r->exccause );
   printf( "epc1  : %p\n", r->epc1 );
   printf( "epc2  : %p\n", r->epc2 );
   printf( "epc3  : %p\n", r->epc3 );
   printf( "excvaddr:%p\n", r->excvaddr );
   printf( "depc: %p\n", r->depc );
//Uncomment this to force a system restore.
//   system_restore();
   CSSettingsLoad( 0 );
   CSPreInit();
   //Create additional socket, etc. here.
   CSInit();
   //Set GPIO16 for INput
   WRITE_PERI_REG(PAD_XPD_DCDC_CONF,
      (READ_PERI_REG(PAD_XPD_DCDC_CONF) & 0xffffffbc) | (uint32)0x1);     // mux configuration for XPD_DCDC and rtc_gpio0 connection
   WRITE_PERI_REG(RTC_GPIO_CONF,
      (READ_PERI_REG(RTC_GPIO_CONF) & (uint32)0xfffffffe) | (uint32)0x0); //mux configuration for out enable
   WRITE_PERI_REG(RTC_GPIO_ENABLE,
      READ_PERI_REG(RTC_GPIO_ENABLE) & (uint32)0xfffffffe);       //out disable
   SetServiceName( "espusb" );
   AddMDNSName( "esp82xx" );
   AddMDNSName( "espusb" );
   AddMDNSService( "_http._tcp", "An ESP8266 Webserver", 80 );
   AddMDNSService( "_esp82xx._udp", "ESP8266 Backend", 7878 );
   //Add a process
   system_os_task(procTask, procTaskPrio, procTaskQueue, procTaskQueueLen);
   //Timer example
   os_timer_disarm(&some_timer);
   os_timer_setfn(&some_timer, (os_timer_func_t *)myTimer, NULL);
   os_timer_arm(&some_timer, SLOWTICK_MS, 1);
   printf( "Boot Ok.\n" );
   usb_init();
    //Set softAP + station mode     %%%%%%%%%%%%%%MOD%%%%%%%%%%%%%
    wifi_set_opmode(STATIONAP_MODE);
    // ESP8266 connect to router.  %%%%%%%%%%%%%%MOD%%%%%%%%%%%%%
    user_set_station_config();
   wifi_set_sleep_type(LIGHT_SLEEP_T);
   wifi_fpm_set_sleep_type(LIGHT_SLEEP_T);
//There is no code in this project that will cause reboots if interrupts are disabled.
void EnterCritical()
void ExitCritical()
