TCP Server Communication AT command configuration
Posted: Fri Jan 26, 2018 1:00 pm
I have an issue with getting my ESP-WROOM-02 module to send data back through the wifi connection after receiving and correctly processing a command through the controller that it is connected to (see the terminal log below). I have successfully used the controller to send commands to the ESP module to configure it on bootup and have successfully connected to it via wifi, sent commands to the controller, and see the response via the ESP module serial port. The only hitch is that the response from the controller is not being transmitted back to the telnet session (putty terminal). I have attached the complete log of the controller boot, configuration and then finally the telnet session where I send commands to the controller and receive the correct response on the serial connection.
Thanks for any help you can provide
Jerry Hubbell
Jerry Hubbell
