You can chat about native SDK questions and issues here.
By berkutta
#76810 I'm trying to get the HSPI Master demo from https://github.com/espressif/esp8266-rt ... SPI_Master working. On Pin D5 it just spits out garbage (I except a nice 10Mhz clock). Any idea what's wrong? I'm using the Espressif RTOS V2.0. I can reproduce the same on a Wemos D2 and Nodemcu board.
By berkutta
#76886 I'm basically meassuring directly on the pin of the Development Board. But well, I think the only real solution is to finally completly switch to ESP32. With the new ESP32 solo this should anyway be the only smart thing to do :D
By rudy
#76891 Change the time base to 10nS or 25nS per division. What you are probably seeing is the result of sampling errors because off too low a horizontal rate. Because it looks fine for me at the higher rate.
