You can chat about native SDK questions and issues here.
By Nikolay
#82483 To manage WiFi, you need to change the function name call_user_start in the library libmain.a, for example, to the name call2user_start, correct one byte in two places, and insert the following function into your program:
void call_user_start()
volatile uint32 * rtc = ((uint32 *) 0x60000700); rtc [4] = 0; rtc [0] = 0;
// works here with sensors. ESP8266 current 15ma instead of 70ma
call2user_start ();
By davydnorris
#82492 Can't you simply call wifi_set_opmode() to turn off the radio by default? Wrap it in an if statement so that you don't repeatedly write to flash:
Code: Select allif (wifi_get_opmode_default()) {
       wifi_set_opmode(NULL_MODE);
You can also use system_phy_set_rfoption(3) to turn off the RF calibration on wake up
