I added 3.0.1 and a patch for c_types.h
Explore... Chat... Share...
rzajac wrote:You can try to use my repo: https://github.com/kicdev/esp-open-sdk
esptool.py write_flash --flash_size 32m 0 boot_v1.7.bin 0x1000 Main-0x01000.bin 0x3fb000 ../library/blank.bin 0x3FE000 ../library/blank.bin 0x3FC000 esp_init_data_default_v08.bin
#define SDK_RF_CAL_ADDR 0x3FB000
#define SDK_PHY_DATA_ADDR 0x3FC000
#define SDK_PARAM_ADDR 0x3FD000
#define SPI_FLASH_SIZE_MAP FLASH_SIZE_32M_MAP_512_512 // FLASH_SIZE_128M_MAP_1024_1024//FLASH_SIZE_32M_MAP_512_512 // 4
#define SDK_PRIV_PARAM_ADDR 0x7C000
#define SYSTEM_PARTITION_CUSTOMER_PRIV_PARAM SYSTEM_PARTITION_CUSTOMER_BEGIN
#define SYSTEM_PARTITION_OTA_SIZE 0x6A000 // upper limit for user.bin
#define SYSTEM_PARTITION_OTA_2_ADDR 0x81000
#define SYSTEM_PARTITION_RF_CAL_ADDR 0x3fb000
#define SYSTEM_PARTITION_PHY_DATA_ADDR 0x3fc000
#define SYSTEM_PARTITION_SYSTEM_PARAMETER_ADDR 0x3fd000
#define SYSTEM_PARTITION_AT_PARAMETER_ADDR. 0x7d000
#define SYSTEM_PARTITION_SSL_CLIENT_CERT_PRIVKEY_ADDR 0x7c000
#define SYSTEM_PARTITION_SSL_CLIENT_CA_ADDR. 0x7b000
#define SYSTEM_PARTITION_WPA2_ENTERPRISE_CERT_PRIVKEY_ADDR 0x7a000
#define SYSTEM_PARTITION_WPA2_ENTERPRISE_CA_ADDR 0x79000
//static const partition_item_t p_table[] = { { SYSTEM_PARTITION_BOOTLOADER, 0x0, 0x1000 }, { SYSTEM_PARTITION_RF_CAL, SDK_RF_CAL_ADDR, 0x1000 }, { SYSTEM_PARTITION_PHY_DATA, SDK_PHY_DATA_ADDR, 0x1000 }, { SYSTEM_PARTITION_SYSTEM_PARAMETER, SDK_PARAM_ADDR, 0x3000 }, { SYSTEM_PARTITION_CUSTOMER_PRIV_PARAM, SDK_PRIV_PARAM_ADDR, 0x1000 }, };
#define EAGLE_FLASH_BIN_ADDR (SYSTEM_PARTITION_CUSTOMER_BEGIN + 1)
#define EAGLE_IROM0TEXT_BIN_ADDR (SYSTEM_PARTITION_CUSTOMER_BEGIN + 2)
// user_pre_init is required from SDK v3.0.0 onwards
// It is used to register the parition map with the SDK, primarily to allow
// the app to use the SDK's OTA capability. We don't make use of that in
// otb-iot and therefore the only info we provide is the mandatory stuff:
// - RF calibration data
// - Physical data
// - System parameter
// The location and length of these are from the 2A SDK getting started guide
void ICACHE_FLASH_ATTR user_pre_init(void)
static const partition_item_t part_table[] = {
// This isn't an ideal approach but there's not much point moving on unless
// or until this has succeeded cos otherwise the SDK will just barf and
// refuse to call user_init()
if(!system_partition_table_regist(part_table, sizeof(part_table)/sizeof(part_table[0]),SPI_FLASH_SIZE_MAP))
os_printf("system_partition_table_regist fail\r\n");
while(1);
os_printf("system_partition_table_regist has been registered!");
return;
