Why is it not possible to call *spi_trans()*...
Posted: Sat Dec 28, 2019 10:13 am
from my own struct?
For code-cleanup reasons I decided to refactor the SPI-part of my code into a separate struct. This struct has an internal variable of type *spi_trans_t* and two buffers (one for *mosi* and *miso* respectively).
But the ESP8266 just keeps crashing if I keep calling *spi_trans()* from inside a function of that struct - why is that?
It works if I create spi_trans_t and the two buffers inside main.c. Anyone else who did encounter that problem?
I am using the latest RTOS SDK btw.
typedef enum STATE {
IDLE = 0,
READY = 1,
WROTE_WRITE_CMD = 2,
WROTE_READ_CMD = 3,
SENT_READ_CLK = 4
} STATE;
typedef struct SPI_HANDLER {
STATE state;
spi_trans_t spi_t;
bool hasPendingTransmit;
uint8_t trans_data[TRANS_ARRAY_LEN];
uint8_t recv_data[RECV_ARRAY_LEN];
void (*finishedWriteRequestCallback)(void);
void (*finishedReadRequestCallback)(uint8_t data);
void (*writeToRAM)(struct SPI_HANDLER*, uint32_t addr, uint8_t data);
void (*readFromRAM)(struct SPI_HANDLER*, uint32_t addr);
void (*notifyTransmitFinished)(struct SPI_HANDLER*);
} SPI_HANDLER;
