QuickFix wrote:No sorry, I don't use the native SDK.
I only looked at your specific question (and noticing you didn't follow the exact steps required) and gave you an answer on the path-problem.
Ok. Thank you very much.
Explore... Chat... Share...
HALU wrote:Hi all,
Until "Configure" `step,
I use minGW32 terminal for "make menuconfig" below.
The error has occured.![]()
make: *** No rule to make target '/home/xxxx/esp/hello_world/menuconfig', stop.
How can I fix this problem?
PS.
I skipped "Setup Path to ESP8266_RTOS_SDK" step. Because I don't know, how can I setup Path?
I setup all steps through minGW32 all, I am not sure, is it correct or not?
