Maybe someone have a similary Problem and can help me.
I listen on a UPD port and periodically send a broadcast. I tested it with PacketSender.
- In the PacketSender I received all Broadcast Messages from all esp8266s's
- if I sende a braodcast message to the ESPs all received the Messages.
But the not the ESPs. What is wrong? the same with on or two UDPs
thanks for any tip.
WiFiUDP Udp;
WiFiUDP Udp1;
unsigned int localUdpPort = 1234; // local port to listen on
char incomingPacket[255]; // buffer for incoming packets
char replyPacket[] = "Hi there! Got the message :-)"; // a reply string to send back
int loop_counter = 0;
char _buffer[255] = "";
unsigned long mc_millis = 0;
int len;
IPAddress mc_ip;
Serial.printf("Connecting to %s ", ssid);
WiFi.begin(ssid, password);
Serial.println(" connected");
mc_ip = WiFi.localIP();
mc_ip[3] = 255;
Udp.begin(localUdpPort);
Serial.printf("Now listening at IP %s, UDP port %d\n", WiFi.localIP().toString().c_str(), localUdpPort);
int packetSize = Udp.parsePacket();
if (packetSize) {
// receive incoming UDP packets
Serial.printf("Received %d bytes from %s, port %d\n", packetSize, Udp.remoteIP().toString().c_str(), Udp.remotePort());
int len = Udp.read(incomingPacket, 255);
if (len > 0) incomingPacket[len] = 0;
Serial.printf("UDP packet contents: %s\n", incomingPacket);
// send back a reply, to the IP address and port we got the packet from
Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
Udp.write(replyPacket);
Udp.endPacket();
yield();
if (millis()>mc_millis) {
mc_millis = millis() + 2000;
//len = sprintf(_buffer,"Node:%08X/%d", ESP.getChipId(),loop_counter);
len = sprintf(_buffer,"Hallo");
Udp1.beginPacket(mc_ip,localUdpPort); // mc_ip, localUdpPort);
Udp1.write((uint8_t *)_buffer, len);
Udp1.endPacket();
++loop_counter;
