Sketch uses 227097 bytes (23%) of program storage space. Maximum is 958448 bytes.
Global variables use 31988 bytes (39%) of dynamic memory, leaving 49932 bytes for local variables. Maximum is 81920 bytes.
warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
Wiring:
Setup #1 -
ESP8266-01 RXD --- Arduino Mega 2560 R3 TXD0 with 200:50ohm voltage divider
ESP8266-01 TXD --- Arduino Mega 2560 R3 RXD0
ESP8266-01 RST --- Pulled high (3.3V 300ohm) with push button GND (BUTTON 1)
ESP8266-01 CH_PD --- Pulled high (3.3V)
ESP8266-01 GND --- Common GND
ESP8266-01 GPIO0 --- Float with push button to GND (BUTTON 2)
ESP8266-01 GPIO2 --- Float
Setup #1 -
ESP8266-01 RXD --- FTDI USB TXD with 200:50ohm voltage divider
ESP8266-01 TXD --- FTDI USB RXD
ESP8266-01 GND --- Common GND w/ FTDI USB GND
(FTDI USB CTS & RTS left alone)
Troubleshooting:
- - I'm powering ESP with external 2.4A 3.3V supply. Common GND
- I push BUTTON 1 & 2 simultaneously. Wait 2 sec. Release 1. Wait 2 sec. Release 2. Wait 2s. Upload code.
- Try removing power supply and reattaching. Then try previous process.
- Try pushing BUTTON 1. Wait 2s. Release 1. Wait 2s. Push BUTTON 2. Wait 2s. Release 2. Wait 2s. Upload code.
- I am using this guide w/ Arduino IDE 1.8.2
- Arduino and FTDI USB are brand new. I tested by connecting RX to TX and checking to see that I receive what I sent in COM.
- I tried only uploading the Bare Minimum sketch (Setup and Loop are empty).
- During upload Arduino RX blinks thrice then TX blinks once. ESP-01 Red LED stays lit. Blue LED dims. Blue LED then blinks when Arduino TX blinks.
- Four different ESP8266-01 modules were tested with same results.
- Two different FTDI USB cables were tested.
- Breadboard and wiring was changed to eliminate the possibility of faulty connections.
I'm going bald from pulling all my hair :O
Any help is greatly appreciated
![Smile :)](./images/smilies/icon_e_smile.gif)
