By espnew
#67343 Hi
I am trying to work with ESP8266 S01 but it does not work.
Code: Select allAT
ERROR
AT+GMR
ERROR
AT+CWMODE=1
ERROR
AT+CWMODE=1
ERROR
AT+CIPMUX=1
ERROR
AT+CIFSR
ERROR
Device is giving error messages, and I do not know that why it happened.
Can you help me?
My connections are as follows :
ESP VCC - 3.3V
ESP CHPD - 3.3V
ESP GND - GND
ESP RX - TX
ESP TX - RX
Thank you!
By QuickFix
#67370
atexit8 wrote:Maybe the device doesn't have the AT firmware loaded.
In that case TS wouldn't have a prompt and "ERROR"-messages like that. :idea:
@espnew: open a serial connection at 74880 baud and reset your ESP.
Have a look at the console and copy-paste the entire contents here on the forum (it should start with ets Jan 8 2013,rst cause:?, boot mode:(?,?), where ? are numbers).
By espnew
#67387
I have tried your commands but it still doesn't work. I received these codes :)
Code: Select alla%H?a%H?a%H?a%H?a%H?a%H?a%H?a%H?a%H?a%H?G?Z?QP@XdY?g
?Q+kSPP?
?WJ5?V?DDVi`\   dX`XPP5}`Y?@Xu{dZ?Zs?G?Z?QP@XdY?g
?Q+kSRP?
?WJ5?V?DDVi`\   dX`XPP5}`Y?@Xu{dZ?ZsXDQUgOX1?Duc
`\?m
`XPP5}|\PP?
`PDZsY?Dw?{`\?`P
sY?Wu!?Duc
`\?m
lY?@V?!`V?Wu!?@Gc ZDQUgOXg?Dvi
`\??D?i?W?!Ke6^dV?D@I+Pk
!@P@\pXDu?P+Pti
@PBPhP+GDP?HBgI?khP?P?Qk
!?!?}?Y*#?t?X
And then I converted my connection of baudrate to 115200 and reset
Code: Select allrlready
AT
ERROR
AT
ERROR
AT+GMR
ERROR
Thank You !
Edit : This ESP worked a few days ago, I have tried new ESP S01 but the problem is continuing.
