By xury
#75126 Hi
I had problems with this module too.
I had swapped resistors and flashing diode.
Very thanks to pilol34 for the solution.
Now everything is working well .
If someone wants use this module with espeasy now is possible with: https://www.letscontrolit.com/forum/vie ... 245#p16998
But only with precompiled binaries attached in first post.
I'm beginner so I can't compile this plugin with a 2.3.0 core. Maybe someone else will do it?
By xury
#75137 Hi pilol34 very thanks for a solution how to fix empty IC and swapped resistors. I had the same.
I have a special request for you. Would you like a compile dump flash for STC15F104W with ASCII steering commands exept binary A0....
It will be easyer to send from bash or url using ser2net plugin.
For example to relay on REL1ON and off REL1OFF ?
By pilol34
#75287
xury wrote:Hi pilol34 very thanks for a solution how to fix empty IC and swapped resistors. I had the same.
Hi Xury;
I'm glad to know that I was able to help you. For your request, I will see if I can do anything but currently I am preparing a version of the package to use the module using the I2C protocol.
Regards, Pilol34.
