Re: Trouble with ESP-01 + 1Ch 5V relay from LC Technology
Posted:
Mon Apr 23, 2018 8:36 pm
by pilol34
Hi Xury;
Between 2 projects I looked for your request and I prepared this little code. As requested, I use the ASCII string "RELAY1=" followed by "0" or "1" to activate the relay. This ASCII chain is not case sensitive.
To enable the relay, you can use:
RELAY1=1
Relay1=1
RelAy1=1
etc.
and to turn off the relay:
I hope this will please you.
Regards, Pilol34.
File: LcWifiRelayUartAsciiV1_0.hex
Code: Select all:0300000002017387
:03000B00020100EF
:10010000C0D0C0E075D00820010B20B019D2017D0D
:10011000047F092126DD0F7D03A2B0EB13FBDF0670
:1001200033F9C201D203DC1D7C03300018EE7009E4
:10013000C2B1880A7E09020145EAD313FA92B1DE00
:1001400004C200D202D0E0D0D032F5F0E52305237E
:10015000543F2434F8E5F0F622E4936006A312013C
:100160004A215922C200C201D202C203E4750C0323
:10017000F50D22787FE4F6D8FD75817F75D0107576
:100180008900758E80758A80758CFED28CD2A9D23A
:10019000B9D2AF12016475B1FB75B203C2B2754436
:1001A00000300217E5226523543F600FC202E522AA
:1001B0000522543F2434F88608D200300332C203AB
:1001C0009001F2E54493601CF9E509B4600221D482
:1001D00040029420697004054421A1E54460BF7584
:1001E000440021C0E5096430C31370B292B2219E6D
:1001F00021A152454C4159313D00A00101A2A0016D
:1002000000A1B00100B1B00000B04F4E0A004F464F
:10021000460A0001004C4320576966692052656C0C
:100220006179204153434949202D206669726D77D9
:100230006172652056312E30206279204C6F7569CD
:09024000732050696C6F6E0A0016
:00000001FF
Posted:
Sat Apr 28, 2018 2:26 am
by Etts
Reprogramming the STC15F104W works brilliantly!! Thanks.
Seems the MCU was not programmed.
BTW, found an English programmer that works with the STC15F104W and on Windows 10 here:
http://www.stcisp.com/STC-ISP_update_%20history.htmlfile is directly downloadable here:
http://www.stcisp.com/_download_stcisp_new.htmlHad to remove R4 as well.
Now only problem is getting CIPSERVER to start automatically when power is cycled.
(Apologies for not following any standards here.
Noob in this forum)
Posted:
Wed May 30, 2018 6:51 pm
by Charles Misiec
I just got relay on/off running without any modification on the hardware. I used Arduino IDE to load the code to ESP01. No additional wiring is necessary.
Follow below example of code of simple Access Point and Web server with buttons to ON/OFF blue led and the relay from LC Technology.
Observe the declaration of const at the top of code:
const byte miBufferON[] = {0xA0, 0x01, 0x01, 0xA2};
const byte miBufferOFF[] = {0xA0, 0x01, 0x00, 0xA1};
Later on
Serial.write(miBufferOFF, sizeof(miBufferOFF));
Serial.write(miBufferON, sizeof(miBufferON));
* NodeMCU/ESP8266 act as AP (Access Point) and simplest Web Server
* to control GPIO (on-board LED)
* Connect to AP "arduino-er", password = "password"
* Open browser, visit 192.168.4.1
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#define LoadPin 2// GPIO2
const char *ssid = "arduino-er";
const char *password = "password";
int stateLED = LOW;
ESP8266WebServer server(80);
void handleRoot() {
response();
void handleLedOn() {
stateLED = LOW;
digitalWrite(LoadPin, stateLED);
response();
void handleLedOff() {
stateLED = HIGH;
response();
const String HtmlHtml = "<html><head>"
"<meta name=\"viewport\" content=\"width=device-width, initial-scale=1\" /></head>";
const String HtmlHtmlClose = "</html>";
const String HtmlTitle = "<h1>CONTROLE REMOTO VIA CELULAR</h1><br/>\n";
const String HtmlLedStateLow = "<big>LED is now <b>ON</b></big><br/>\n";
const String HtmlLedStateHigh = "<big>LED is now <b>OFF</b></big><br/>\n";
const String HtmlButtons =
"<a href=\"LEDOn\"><button style=\"display: block; width: 100%;\">ON</button></a><br/>"
"<a href=\"LEDOff\"><button style=\"display: block; width: 100%;\">OFF</button></a><br/>";
void response(){
String htmlRes = HtmlHtml + HtmlTitle;
if(stateLED == LOW){
htmlRes += HtmlLedStateLow;
}else{
htmlRes += HtmlLedStateHigh;
htmlRes += HtmlButtons;
htmlRes += HtmlHtmlClose;
server.send(200, "text/html", htmlRes);
delay(1000);
Serial.begin(9600);
WiFi.softAP(ssid, password);
IPAddress apip = WiFi.softAPIP();
Serial.print("visit: \n");
Serial.println(apip);
server.on("/", handleRoot);
server.on("/LEDOn", handleLedOn);
server.on("/LEDOff", handleLedOff);
server.begin();
Serial.println("HTTP server beginned");
pinMode(LoadPin, OUTPUT);
server.handleClient();
Posted:
Thu Jun 21, 2018 8:20 pm
by Dean24
I just got one of these ESP-01 plus 1 ch relays from China a couple days ago. The back of the relay bd says they are up to V3 now. but of course I couldn't get it to work. I wanted to use the Blynk app for my iPhone as it looked a reasonably straight forward task and I was familiar with the Arduino bd but not the ESP8266.
After a lot of reading and trial and error (including this thread) I could get as far as toggling the GPIO0 or GPIO2 but didn't want to hack the board as so many on this thread have done by connecting the GPIO to a transistor to drive the relay. I found once the blynk app had written to drive the GPIO0 or 2, I could no longer get my arduino code to then read these pins and drive the relay via a serial write to the onboard chip. Not having used Blynk before I didn't realize the potential to write to virtual pins.
So, once I setup my Blynk button to turn V0 virtual pin on or off, this following bit of arduino code flashed to the generic 8266 bd on the relay bd worked like a charm. Note: I unplugged the 8266 bd and temporarily tied GPIO0 to ground and then plugged it into a USB to ESP8266 WiFi module Adaptor to load the code via the Arduino app.
Hope this helps somebody to take a few less steps than I did.
/*control relay looking at virtual pin sent from Blynk and serial writing commands to chip onboard Relay board - works */
#define BLYNK_PRINT Serial
#include <BlynkSimpleEsp8266.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "yourAuthToken";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "yourSSID";
char pass[] = "yourPassword";
byte relON[] = {0xA0, 0x01, 0x01, 0xA2}; //Hex command to send to serial for open relay
byte relOFF[] = {0xA0, 0x01, 0x00, 0xA1}; //Hex command to send to serial for close relay
void setup()
// Debug console
Serial.begin(9600);
Blynk.begin(auth, ssid, pass);
// You can also specify server: (Blynk sample code)
//Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 8442);
//Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8442);
// Relay on off
BLYNK_WRITE(V0) {
int button = param.asInt(); // read button
if (button == 1) {
Serial.write(relON, sizeof(relON));
else {
Serial.write(relOFF, sizeof(relOFF));
void loop()
Blynk.run();
