Here is the output from flashing
Checking target MCU ...
MCU type: STC15F104W
F/W version: 7.2.5Q
Current H/W Option:
. Current system clock source is internal IRC oscillator
. IRC frequency: 11.069MHz
. Wakeup Timer frequency: 36.987KHz
. Do not detect the level of P3.2 and P3.3 next download
. Power-on reset, use the extra power-on delay
. RESET pin behaves as I/O pin
. Reset while detect a Low-Voltage
. Thresh voltage level of the built-in LVD : 3.82 V
. Inhibit EEPROM operation under Low-Voltage
. Hardware do not enable Watch-Dog-Timer
. Watch-Dog-Timer pre-scalar : 256
. Watch-Dog-Timer stop count in idle mode
. Program can modify the Watch-Dog-Timer scalar
. Do not erase user EEPROM area at next download
. Do not control 485 at next download
. Do not check user password next download
. TXD is independent IO
. TXD pin as quasi-bidirectional mode after reset
. P3.3 output HIGH level after reset
. Testing time: 2017-6-5
. MCU type: STC15F104W
F/W version: 7.2.5Q
Adjusting frequency ... [0.360"]
Adjusted frequency: 11.083MHz (0.217%)
Re-handshaking ... Successful [0.047"]
Current Baudrate: 9600
Erasing MCU flash ... OK ! [0.391"]
MCU ID : F29424751026C9
Programming user code ... OK ! [1.797"]
Programming OPTIONS ... OK ! [0.140"]
H/W Option upgrade to:
. IRC frequency: 11.083MHz
. MCU ID : F29424751026C9
F/W version: 7.2.5Q
. Set frequency: 11.059MHz
. Adjusted frequency: 11.083MHz
. Trim error: 0.217%
Complete !(2018-09-10 13:31:00)Below two screens from the programming software (one with loaded Buffer shown, one with COM Helper), i'm not sure if i need any EEPROM data or if my settings are correct. Its all on default. In the COM Helper window you can see the RXs increment, but no TX or LED flashing
https://imgur.com/a/hOtahmE
http://imgur.com/a/GYh3n6x
