By vindhyachal.takniki
#60591 I have node MCU V0.9 board & SD card shield for arduino uno. On sd card, I have to make a file in FAT32 format to store data. Sd card has four out pins: CS, MISo, MOSI, CLK
1. Can I use this library from arduino in node MCU for sd card?
2. What should be the pin conenction between two boards?
