By manny009
#63641 #include <ESP8266WiFi.h>
const char* ssid = "xxxxxxxxx";//type your ssid
const char* password = "xxxxxxx";//type your password
char val = 0; //variable to store the char read from the RFID button
/*Using RFID ID-12 to read unique character that is assigned to each RFID button or tag*/
WiFiServer server(80);
Serial.begin(9600); //connect to the serial port
delay(10);
// Connect to WiFi network
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
// Start the server
server.begin();
// Print the IP address
Serial.print("Use this URL to connect: ");
Serial.print("http://");
Serial.print(WiFi.localIP());
Serial.println("/");
void loop ()
//read the serial port
if(Serial.available()){
char val = Serial.read();//read from one char from the ID-12 and store it
Serial.print(val); //display the char in the serial monitor
if (!client) {
return;
// Return the response
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println(""); // do not forget this one
client.println("<!DOCTYPE HTML>");
client.println("<html>");
client.println("</br>");
client.print("RFID Tag No = ");
client.println(val);
delay(1);
Serial.println("Client disonnected");
Serial.println("");
Anyone tell me why I cannot post my serial data to the web server?
I am writing the serial data to char val then writing val to the web server but it will not display on the the browser.
By manny009
#63672
martinayotte wrote:When you do "char val = Serial.read()" the "val" is a local variable and not using the global one.
Simply do "val = Serial.read()" instead ...
so I changes val to the global variable but still no printout on the web server.
Could it be that it is reading one bit at a time? thus not printing out the whole 13 characters of the RFID tag?
void loop ()
