By surya arief
#67937 I want, if wifi connect to esp, then led is on,
if not connect, then led is off
but this below code not work, and ssid cannot scaned.
iam use NodeMcu V3.
#include <ESP8266WiFiMulti.h>
ESP8266WiFiMulti WiFiMulti;
const int led = 7; //pin on GPIO13 connected to LED
void setup(){
pinMode(led, OUTPUT);
digitalWrite(led, LOW); //turn off led
// set Wifi SSID and password
WiFiMulti.addAP("mywifi", "12345678");
void loop(){
// scanning wifi with SSID and password above
if (( == WL_CONNECTED))
{ digitalWrite(ledA, HIGH); //turn on led }
{digitalWrite(ledA, LOW); //turn off led }}
By atexit8
#68004 This code works for me.
const char* ssid = "ssid";
const char* password = "password";
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, LOW);
  // Connect to WiFi network
   WiFi.begin(ssid, password);
  //put your LED code here
By surya arief
#68013 Code above is esp8266 as client not accesspoint, if esp8266 connect to hotspot, then led is on.
is possible if i want esp8266 as accesspoint, not as client?
So if there is client connect to esp8266, then led is on.
By schufti
are you decided yet if the LED is on gpio 7 or 13 ?
If you intend to use nodemcu pin marked "D7" you should write
const int led = D7
or alternatively
const int led = 13
maybe that will make your code work ....
