By Hash
#69866 Hi I purchased an echo dot and its great. I got Fauxmo to emulate a wemo device and working with the echo dot. Voice control for relays is excellent but i would also like to use an android app to control the relays. The problem i have is when i try to turn any relay on or off manually through the webserver gpio url request it causes the wemos d1 mini to not respond. I can only use either alexa voice control or the webserver not both at the same time. Ive uploaded my arduino sketch. Appreciate any help Thanks.
By EduardoM
#79154 Hi
Is possible to share this code? I try to do this, controls the relays usin alexa and using android app too. But I don't know how start.
Best regards
