It's just me or sometimes after uploading a simple sketch (blink led) the code doesn't work (no boot properly) ?
I have to repeat the same procedure a couple times in order to put the code running.
Thank you in advance.
Regards,
Luiz
Explore... Chat... Share...
Well I returned the two defective NodeMCU, and out[…]
Interesting. I have used 12Fs exclusively and I h[…]
mingw32-make.exe: *** [build / app.out] Error 1 […]
Hi Xury; Between 2 projects I looked for your req[…]
Hello I would like to send commands to esp8266 vi[…]
What do you think actually solved the problem : Wa[…]
Riky, I am also new to ESP8266 but I solved the sa[…]
schufti, thanks for verifying that it should work […]
Can't help you with Arduino IDE since I'm not usin[…]
Hi. Not sure but it looks like the ESP.updateSket[…]
Follow US on Twitter and get ESP8266 news and updates first.
