By mrlightsman
#74889 Thank you for your replies. I have abandoned the idea of using multi or broadcast. It seems my router is blocking anything beyond unicast because of a udp flood filter.
I temporarily disabled it and got broadcast to work... sometimes. You weren’t kidding about reliability. It is awful compared to unicast.
Any thoughts about how to get around changing destination ip addresses short of address reservations in router or moving to static ip? I really prefer to stick with dhcp.
Any way to make two or more esp communicate with mdns or similar technique? No computer involved in the set up so no bonjour. Strictly esp talking to each other over home Wi-Fi.
Thanks.
By rudy
#74891
I have looked at this. I have not worked things out yet but it is what I had planned for my system. This is the way I think I will go about it.
I will use mDNS as a way to discover devices and then make a list of devices and their IP addresses. After that I will use unicast to communicate to devices on the list.
mDNS uses multicast and from my tests I don't always see a response to a discovery request.
What you should try is the mDNS-SD_Extended.ino example on one ESP and the mDNS_Web_Server.ino example on one or more ESPs. Make sure that you have the query request have matching setups in the other devices.
Code: Select allint n = MDNS.queryService("esp", "tcp");  // Send out query for [u]esp[/u] [u]tcp[/u] services
That is in the mDNS-SD_Extended.ino example. Make sure that the two fields match what you have in the other devices. The mDNS_webserver example has the ESP set for the following, and it will not match the above query.
Code: Select all  // Add service to MDNS-SD
  MDNS.addService("http", "tcp", 80);
I'm also going to throw this out there. It is code that displays the packets that an ESP hears on the multicast address and port used by mDNS. I use this rather than wireshark when I just want to see real time traffic in a terminal window.
Code: Select all// Displays mDNS packets on multicast - 224.0.0.251:5353
#include <WiFiUDP.h>
int status = WL_IDLE_STATUS;
const char* ssid = "MTS61752";
const char* password = "6900979039";
const char* WiFi_hostname = "esp27.107";
unsigned int localPort = 12345; // local port to listen for UDP packets
byte packetBuffer[512]; //buffer to hold incoming and outgoing packets
// A UDP instance to let us send and receive packets over UDP
WiFiUDP Udp;
// Multicast declarations
IPAddress ipMulti(224, 0, 0, 251);
unsigned int portMulti = 5353; // local port to listen on
void setup()
  // Open serial communications and wait for port to open:
  Serial.println("");
  Serial.println("mDNS-display.ino");
  Serial.print("Udp Multicast mDNS listener");
  Serial.print("");
  WiFi.hostname(WiFi_hostname);
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  // Wait for connect to AP
  Serial.print("[Connecting]");
  Serial.print(ssid);
  int tries = 0;
    Serial.print(".");
    tries++;
    if (tries > 30) {
      break;
  printWifiStatus();
  Serial.println("Connected to wifi");
  Serial.print("");
  Serial.print("Udp Multicast mDNS listener at : ");
  Serial.print(ipMulti);
  Serial.print(":");
  Serial.println(portMulti);
  Udp.beginMulticast(WiFi.localIP(), ipMulti, portMulti);
  Serial.print("");
void loop()
  int numBytes = Udp.parsePacket();    // number of bytes
  if ( numBytes )                      // if > 0
    /////// UDP packet can be a multicast packet or specific to this device's own IP
    Serial.print(millis() / 1000);
    Serial.print("seconds :Packet of ");
    Serial.print(numBytes);
    Serial.print(" received from ");
    Serial.print(Udp.remoteIP());
    Serial.print(":");
    Serial.println(Udp.remotePort());
    // We've received a packet, read the data from it
    Udp.read(packetBuffer, numBytes); // read the packet into the buffer
    // display the packet contents in HEX
    for (int i = 1; i <= numBytes; i++) {
      if (packetBuffer[i - 1] < 16) {
        Serial.print("0"); // leading 0 if < 10h
      Serial.print(packetBuffer[i - 1], HEX);
      if (i % 32 == 0) {
      else Serial.print(' ');
    } // end for
    Serial.println("--------------------------");
    // send a reply, to the IP address and port that sent us the packet we received
    // the receipient will get a packet with this device's specific IP and port
    //Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
    //Udp.write("My ChipId:");
    //Udp.print(ESP.getChipId());
    //Udp.endPacket();
    // Serial.println(ESP.getChipId());   //??? why
  } // end if
  delay(20);
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
By schufti
#74898 please people don't mix up ip-multicast with ip-broadcast.
they are similar but not the same.
whereas multicast requires the transmitter to know the clients (or the client to register at least with a distribution point/proxy), only broadcast supports anonymous receivers.
By rudy
#74901
schufti wrote:please people don't mix up ip-multicast with ip-broadcast.
I agree that ip-multicast is not the same as ip-broadcast.
But I have found nothing to indicate that the transmitter needs any awareness of who is listening. As far as I can tell a device can listen to a multicast address and port and it will receive those packets. From what I have found, receivers are anonymous. I am talking about on a local network, as that is what the OP and I are interested in. If you have anything to show that this is not the case them please direct me to the information. I certainly want to know.
