By RogerF
#74945 How to use NodeMCU ESP8266 on Linux/Ubuntu?
I have an old PC dual-booted with Windows XP and Ubuntu 12.02.4 LTS. Using Windows XP, I attached a NodeMCU ESP8266 using LuaLoader with a USB cable to COM5 and everything works well. I can load and run LUA programs on the ESP8266 with no problems.
Now I would like to do the same thing using the Ubuntu system, but I don't know where to start. Is there a Linux program similar to LuaLoader? If not, how do I load and run a Lua program using Linux/Ubuntu on COM5? I don't know a lot about Ubuntu, so basic instructions would be helpful. Thanks in advance for any suggestions.
By RogerF
#74959 Since posting the question above, I have done the following in Ubuntu:
sudo apt-get install screen
screen /dev/ttyUSB0
This actually worked and I received the command prompt from the ESP8266 and was able to enter several commands. This was much simpler than I expected. Now I want to figure out how to upload LUA program files to the ESP8266. Any advice on the easiest way to do that would be appreciated.
