By Vijay Gill
#75041 Hi all,
Back again with another power related finding and question. After having gone through so many pages about using LDO to power that my eyes almost bled, I just hooked up a WEMOS mini D1 (R1) to two AAA Duracell batteries (i.e. 1.5V X 2) and got the blink example of Arduino studio successfully running on it!
Now, was I doing things arse-wise? If the board runs on 3V directly from batteries, why should I bother about LDO and all that stuff?
Please let me know as I am crawling here (in ESP8266 world) before I learn to walk.
Thanks
Vijay
By rudy
#75045 Blink doesn't work the ESP8266 much. WiFi will take higher current when it is transmitting. Still within the capability of AA batteries. And you should not need a regulator to bring the voltage down to the range the chip is rated for. New AA batteries (non-rechargeable) have a maximum voltage of about 1.6 volts. No problem as far as maximum voltage goes.
The problem is when the batteries are not in new condition. The ESP8266 has a voltage specification of Operating Voltage 2.5V ~ 3.6V. https://www.espressif.com/sites/default ... eet_en.pdf This is for the ESP8266 chip alone.
A datasheet for the ESP-12S lists the recommended range of 3.0 - 3.6 volts. https://www.elecrow.com/download/ESP-12 ... Manual.pdf
I have had problems with modules when the voltage dipped below 3.0 volts.
