By FranckM
#75505 I have 4 ESP8266 running the same code controlling APA102 leds using FastLED. The program has multiple "modes" showing different animations. The current mode is simply controlled by an uint8_t variable.
I'm trying to set one ESP as AP and the other 3 as Station, so when I change the mode on the AP I can send the variable to the 3 stations.
I succeeded by using UDP, but the lag is considerable and my stations end up de-synced by half a second of what the AP is showing.
Is there a way to do this with static IPs using write() and read()? The examples I found were stations sending data to the AP. I want the AP to send data to the 3 stations.
Thank you
By schufti
#75507 a) maybe:
send new pattern via udp broadcast to stations first, then switch on AP
or
use 5 modules and let the 5th be controller only, the other 4 should receive and react to udp broadcast (almost) synchronously
b) exact solution:
have all modules sync to ntp time and send exact timestamps when to change pattern ...
By schufti
#75508 a) maybe:
or
b) exact solution:
n.b.: you'd probably have to do your own full implementation of ntp to get sub-second sync.
