By hisbullaha
#75864 hey guys i have a project about IC PT2256, thats IC was Audio volume digital potentiometer.
the IC dont have I2C connection but only need 2 button that bridge them to groung.
I wondering can control the IC with NodeMCU, so what must i do? making virtual ground or virtual button
if make virtual button, NPN Transistor as switch or Relay Module
Thank you :D
By rudy
#75870
hisbullaha wrote:NPN Transistor as switch or Relay Module
Use transistors. NPN with base resistors, or logic level mosfets that only require 3 volts gate drive. Don't bother with relays unless you need isolation between the two circuits. Even then I would use optocouplers instead of relays.
