By Drpepper
#77164 Around Two Years ago I used an ESP8266EX to control a light switch. It worked great, and all was good.
Last week a friend ask me to help set up a garage door opener and I had some more ESP8266EX’s so I started to work.
The ESP8266EX I am using is a Manufacturer: e0 Device: 4014
The FTDI is a 1232.
The IDE is Arduino 1.8.5
The ESP lib is esp8266 Community 2.4.1
The ESP Lib Selected is “Generic ESP8266 Module”
The test script is:
pinMode(0, OUTPUT);
digitalWrite(0, HIGH);
digitalWrite(0, LOW);
Everything looks good. I can load the script. It reaches 100% then the red light goes very dim and that is it. Nothing…
I reboot, 50% of the time the red light is bright, and sometimes I can get some console logging that has this:
Ets Jan 8 2013, rst cause :4 Boot mode:(3,7)
Wdt reset
Load 0x4010f000, len 1384, room 16
Tail 8
Chksum 0x2d
Csum 0x2d
V614f7c32
~ld
Any Hint as to what I am doing wrong?
By rudy
#77201
How do you know that your power supply is not the cause?
By mgsecord62
#77214 It has been my experience that the FTDI does not have enough + 3.3 volt power to operate the esp8266 especially if it is being supplied by the 232 chip.
