By Hamdan Mahmood
#78671 Hello, when i try to compile the wifiwebserver example,given in ESP8266WiFi library,i get the following load of errors:
In file included from C:\Users\wwwsm\Documents\Arduino\libraries\ESP8266WiFi\src/ESP8266WiFi.h:40:0,
from C:\Users\wwwsm\AppData\Local\Temp\arduino_modified_sketch_526765\WiFiWebServer.ino:10:
C:\Users\wwwsm\Documents\Arduino\libraries\ESP8266WiFi\src/WiFiServer.h:52:14: error: invalid abstract return type for member function 'WiFiClient WiFiServer::available(uint8_t*)'
WiFiClient available(uint8_t* status = NULL);
In file included from C:\Users\wwwsm\Documents\Arduino\libraries\ESP8266WiFi\src/ESP8266WiFi.h:39:0,
C:\Users\wwwsm\Documents\Arduino\libraries\ESP8266WiFi\src/WiFiClient.h:45:7: note: because the following virtual functions are pure within 'WiFiClient':
class WiFiClient : public Client, public SList<WiFiClient> {
In file included from C:\Users\wwwsm\Documents\Arduino\libraries\ESP8266WiFi\src/WiFiClient.h:27:0,
from C:\Users\wwwsm\Documents\Arduino\libraries\ESP8266WiFi\src/ESP8266WiFi.h:39,
C:\Users\wwwsm\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Client.h:37:22: note: virtual void Client::flush()
virtual void flush() = 0;
C:\Users\wwwsm\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Client.h:38:22: note: virtual void Client::stop()
virtual void stop() = 0;
In file included from C:\Users\wwwsm\Documents\Arduino\libraries\ESP8266WiFi\src/WiFiServerSecure.h:21:0,
from C:\Users\wwwsm\Documents\Arduino\libraries\ESP8266WiFi\src/ESP8266WiFi.h:41,
C:\Users\wwwsm\Documents\Arduino\libraries\ESP8266WiFi\src/WiFiServerSecureBearSSL.h:58:22: error: invalid abstract return type for member function 'BearSSL::WiFiClientSecure BearSSL::WiFiServerSecure::available(uint8_t*)'
WiFiClientSecure available(uint8_t* status = NULL);
In file included from C:\Users\wwwsm\Documents\Arduino\libraries\ESP8266WiFi\src/WiFiServerSecureBearSSL.h:24:0,
from C:\Users\wwwsm\Documents\Arduino\libraries\ESP8266WiFi\src/WiFiServerSecure.h:21,
C:\Users\wwwsm\Documents\Arduino\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:34:7: note: because the following virtual functions are pure within 'BearSSL::WiFiClientSecure':
class WiFiClientSecure : public WiFiClient {
In file included from C:\Users\wwwsm\Documents\Arduino\libraries\ESP8266WiFi\src/WiFiServerSecure.h:20:0,
C:\Users\wwwsm\Documents\Arduino\libraries\ESP8266WiFi\src/WiFiServerSecureAxTLS.h:36:20: error: invalid abstract return type for member function 'axTLS::WiFiClientSecure axTLS::WiFiServerSecure::available(uint8_t*)'
In file included from C:\Users\wwwsm\Documents\Arduino\libraries\ESP8266WiFi\src/WiFiClientSecure.h:23:0,
from C:\Users\wwwsm\Documents\Arduino\libraries\ESP8266WiFi\src/ESP8266WiFi.h:42,
C:\Users\wwwsm\Documents\Arduino\libraries\ESP8266WiFi\src/WiFiClientSecureAxTLS.h:33:7: note: because the following virtual functions are pure within 'axTLS::WiFiClientSecure':
C:\Users\wwwsm\AppData\Local\Temp\arduino_modified_sketch_526765\WiFiWebServer.ino: In function 'void loop()':
WiFiWebServer:53:40: error: cannot allocate an object of abstract type 'WiFiClient'
C:\Users\wwwsm\Documents\Arduino\libraries\ESP8266WiFi\src/WiFiClient.h:45:7: note: since type 'WiFiClient' has pure virtual functions
WiFiWebServer:53:14: error: cannot declare variable 'client' to be of abstract type 'WiFiClient'
Multiple libraries were found for "ESP8266WiFi.h"
Used: C:\Users\wwwsm\Documents\Arduino\libraries\ESP8266WiFi
Not used: C:\Users\wwwsm\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi
exit status 1
By the way,i have tried installing arduino again, AND sqapping computers entirely... It didn't work
Help would be much, much, much appreciated.
Thank You! :ugeek: :D ;) 8-) :roll: :mrgreen: :geek: :ugeek: :idea: :| :cry:
By Pablo2048
#78677 Well, the problem is IMHO obvious - see
Code: Select allUsed: C:\Users\wwwsm\Documents\Arduino\libraries\ESP8266WiFi
It seems like you have installed another library, named ESP8266WiFi. Try to remove this library first, or install Arduino IDE in portable version and install ESP8266 package into this installation only.
By Hamdan Mahmood
#78687
Pablo2048 wrote:Well, the problem is IMHO obvious - see
Unfortunately i already tried deleting that "unused" library. It seems to give the same error still?
ThankYou for quick reply! :D
