By Fiservedpi
#78754 Hey Now!!!,
First time posting here im trying to boot my ESP 01 for the first time after flashing an arduino sketch to control LED's over MQTT/WiFi but it never connects to the WiFi, i am using google mesh router wich has no option to toggle 5 GHZ or 2.4 GHz if that helps, Also here are the libraries included in the sketch
Code: Select all#include <ArduinoJson.h>
#include <PubSubClient.h>
#include "FastLED.h"
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
By btidey
#78757 1. The ESP modules will only connect on 2.4GHz
2. You need to give more details if you want help on why it won't connect. A list of libraries does not help.
a) The sketch code
b) Hardware being used
c) What symptoms you are seeing. E.g. serial port messages
By Fiservedpi
#78761
btidey wrote:1. The ESP modules will only connect on 2.4GHz
a) The sketch code
Ok thanks for the reply,
here is the ouput from the serial monitor
Code: Select all....
 ets Jan  8 2013,rst cause:1, boot mode:(3,7)
tail 8
chksum 0x2d
csum 0x2d
vbb28d4a3
~ld
Connecting to MeshNet
Here is a link to my sketch https://hastebin.com/neqihaxoka.cpp
I am flashing the 1 MB Esp -01 black with Arduino 1.8.7 using and ftdi adapter and breadboard adapter i made, any help is much appreciated
thanks in advance
